Haut Medoc
- Joined
- Jun 29, 2004
- 10,645
Re: Frustrated! Won't rev up, 5.8L, been working on it a while!
There should be a fitting on the tank near the back where the fuel line that feeds the water separater goes from horizontal to vertical.....
That is where the anti-siphon valve should be & the pickup screen at the bottom of that tube.....
Nope, but that is most likely near where the fuel vent hose is.........Don,
Thanks again for the advice. I typed that wrong and meant to say I regapped the points, not the plugs. Plugs are new as of yesterday and are at .030.
I have printed off the fuel system checklist and will take it with me tonight. I will pull the vent hose to see if it is clogged and the fuel pickup hose to see if the screen is blocked. I sure do hope it is one of these that is the problem.
Mechanical advance on distributor seems to work fine.
Question, I know when I first got the boat I had to suck the old gas out of the tank and I had to take off the round cover on the top of the tank that holds the float. This was the only hole big enough to get my hose down in to suck it out. If I didn't get that selaed and tight when I put that cover back could it cause an issue? Fuel gauge is reading 3/4 full when tank is slam full so maybe my float needs adjustment (least of my worries).
I don't have a gauge to check fuel system but will see about getting one.
Thanks,
Jeff
