fuel line help
hitace
the boat i bought new had a 115 4 stroke 2007 yamaha but i quickly sold that and bought a carb 150 OMC johnson the fuel lines going from the gas tank to the fuel filter is from the 4 stroke 115 even tho i have a 150 carb 2 stroke on there.the outboard seems to run fine. but are the fuel lines from the 115 yamha smaller?should they be changed?could it be hurting perfomance?
WillyBWright
Re: fuel line help
The Yamaha was fitted with am 8mm hose which is equal to 5/16". V-6s should have 3/8" line.
hitace
Re: fuel line help
so could this be starving my outboard from fuel?hurting its perfomance?
thnaks
Bob_VT
Re: fuel line help
It should not have much effect we are only talking about 1/16".
How is the fuel pump on the 150? You are going to have to start from scratch.
Compression
Carbs cleaned
Spark
Do you have a primer bulb? Try pumping the bulb at WOT throttle and see if that makes a differance. If it does then it is the fuel pump.
Just for fun go to the larger fuel line ..... they are not that much money.
