Another retired guy
Ensign
- Joined
- Jun 17, 2012
- 940
Re: fuel overflow line --- any way to avoid losing fuel
Where is your vent fitting in relation to the fuel filler - higher or lower? For example on my boat the thru hull vent fitting is about 2" higher than the filler fitting. If I overfill the gas comes back up the filler hose BEFORE it comes out of the vent.
If none of the above suggestions work for you, one option would be to replace the current vent line with a new one to a new vent fitting located at a higher point on the hull.
