flashback
- Joined
- Jun 28, 2002
- 4,367
just a PS nextel, If I have helped you I'm happy but please understand that I am experimenting, my project is ongoing. I have no idea of how what I'm doing will hold up. I'm in the process of getting the rubber parts in the transom assembly replaced along with the bearing and I have only done it once on a boat 20 years ago older than ours.yep, my pump bracket is mounted to the bracket on the manifold that the filter was originally mounted to, I had to drill a couple of extra holes in the pump bracket which I mounted up side down for ease. then I mounted the filter to the bulkhead just above the gas tank. Tried to keep things as low as possible with in reason..
electric pumps aren't the best suckers..
I hot wired the pump after I plumbed it just to see if it could lift gas from the tank and it charged the carb faster than I expected so I'm hoping it will be ok.
