Fuel Pump issue?
Calibra
Hi
I have a 15HP 1999 2-Stroke Johnson Engine
The engine is in a bin (Tank for better word) with water. If I put the fuel tank on the floor the engine runs for about 2 - 5 mins and stalls.
If I lift tank higher than the engine, it keeps running.
Is this a fuel pump issue even though it's new
I have checked for air leaks and even replaced the fuel lines.
Thanks
James
The pump is driven by the positive crankcase compression pulse and a slight negative pulse from crankcase.--------Perhaps there is an issue there.
Calibra
Oh dear, I am not sure where to go with that.
I need to do some googling I think. I need to work out how this pulse works so I can troubleshoot it.
On a cold engine, each cylinder is 130psi, so that's OK.
Crosbyman
how high is the bin relative to the tank ??? is this an issue in the running world.....with probably less than 2 feet between engine and tank bottom ?
jakedaawg
If the tank is properly vented, and you have put a new brp bulb and hose assy on just rebuild the pump kit #0438616. $20
Calibra
Hi
Sorry for bringing an old thread back, I wanted to tell you the problem was resolved.
For details of the problem, see post #1
I replaced the following
- Rebuilt the carb (The first time I've done this)
- Rebuilt the Fuel pump (The first time I've done this)
- Changed fuel hoses from carb to fuel tank
- I changed the primer bulb
The fix was.......
If you look on the engine block were the fuel pump screws on, there is a third whole in the middle. That whole was blocked.
Hopefully this may help someone else
James
