Furrylittleotter
- Joined
- Oct 16, 2014
- 167
Here uou can see some if the aluminum I have been collecting. The 1/2" by 4 angle will be the engine cradle $20 from Shipwreck marine, the aluminum ladder will most likely be cut up and used to build the stern (no wood, remember?)$120 from craplist and the 3/8" by 4 by 1.5" C channel goes to the outside of the existing Starcraft stringers, the 2" architectural U channel will go side to side to support the floor, which will be 2" of pink foam on top of carved foam (building hot wire) and then the top will either be plastic or aluminum sheet (not sure) and then rubber mat over that. I want it blood proof.
