Furrylittleotter
- Joined
- Oct 16, 2014
- 167
Hey, I'm all about Barbq. IN our house it was a religion. Carolina Bar B Q, Preferably Wilber's in Goldsboro!
Tried some spinning on the Boatisserie. Because I do not have a bar running front to back I am unable to align my hubs perfectly, It spins but it wants to move the supporting structure when it does. I added some front to rear braces and loosened the lug nuts to allow "Wobble" but it wasn't enough play and it still moves the support.
I am going to remove one of the bearings and install a U-joint and flange. that should give me plenty of "Wobble".
if that doesn't fix it I will mount the other mount on casters so it can move.
I also made a big order (mostly from iBoats)
Gluvit (2 qts)
Closed all aluminum rivets 3/16 and 1/8( for dash work and interior)
Solid rivets
Dripless shaft seal
Prop bushing
Keyswitch
on/off switches
Deadman switch with lanyard
I think I will use an HVLP sprayer for primer and paint so I am trying to find a self powered one on Craplist...
Planning to paint bottom Rustoleum "Almond" up to rub rail mid way up to top rub rail , then a stripe of polished aluminum and the top white, bare aluminum inside with Sharkhide.
At some point someone took an angle grinder to the boat with a heavy wire wheel so I already bought a Pneumatic inline sander to level that.
I also have a huge polisher, several 2" wide polishing wheels (sewn and unsewn) three types of rouge and a Cyclo polisher for the final finish?Should be pretty cool.
Hopefull I can hire someone to help me with that part, my shoulders are pretty bad off. That stripe will probably get shark hide as well.
Neil
Gluvit (2 qts)
Solid rivets
Dripless shaft seal
Prop bushing
Keyswitch
on/off switches
Neil
