zildjian29
Thread starter- Joined
- Jul 7, 2011
- 80
I'm trying to find out what amp fuses I need for my gauges. They are the round glass type. Where can I find this information?
gauges are not normally fused, what are you trying to fix?
achris , heres a tip to check the advanced timing marks on a harmonic balancer.normally the damper goes CCW with rpm and the mark disappears. But if you paint 3 white dots from the original damper groove clockwise and advance the rpm the actual timing mark goes CCW and the dots will approach the 0 mark. So if you initally set the groove at 8 BTDC and bring up the rpm your dots are 10 degrees apart the midway distance between the 2nd and 3rd dot should be approaching the 0 part of the timing tab , this indicates your initial 8 plus approx 22 degrees of advance.
someday when the fancy tools just stop working you now know how to set and check the advanced timing
