Re: Gamefisher 7.5 HP
You should carefully inspect it for small cracks. I just replaced a bad one this weekend. Looked good until I pinched it with my fingers. Showed up good then. I don't think fuel pump is used when running off of onboard fuel tank, only when external tank is used. Gravity should feed carb when onboard tank is used. Not to sound like a broken record, but high speed jet may need cleaned. When you take off float bowl, the screw that holds bowl on is the main (high speed) jet. There should be a small hole in one (or both) sides of jet. Make sure there is no crud plugging that orifice. If it's plugged, it can do what you described. Also check fuel inlet "block" where hose attaches to carb. 2 phillips screws hold it on. There will be a flapper valve, and gasket behind plate. Make sure flapper valve flaps are NOT curled up. They should fit flat against block. If they don't seal, it could give you problems. Behind that gasket (if you can carefully remove it) is a screen. If debris from tank got through hose, it will gather in that screen. Carefully with a toothpick pull screen up. After cleaning, just push it in with finger. That cloged screen could also cause your condition. Keep me posted.
