FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
In Other News . . .
You will notice a few enchancements to the forums to make your experience better. These include: Email Notifications, Thread Previews, Thread Starter Notation, and Emoji Options on the 'Like' icon. . .
Additionally, the merchant portions of the website have been updated and are now operational. . . . Check out iBoats for all your boating gear.
Does anyone know if I can install the transducer for a garmin 100 Echo in the hull? It is a fiberglass bowrider.Seen different opinions on this. Thanks.
From what I can find Garmin doesn't make a thru-hull transducer for the 100. Could call Garmin (800) 721-1373
You could possibly mount it inside and have it shoot thru the hull but then you would loose the temperature reading. You could add some water to your bilge and place the transducer on the hull and hold it there with a bag of rocks or sand. May have to move it around to find the best spot for all speeds.
I don't know what type of boat you have but mine had in the owners manual the install location of where to put the transducer if you were going to shoot through the hull. As for temp you will get it, it will just take a bit for the hull temp to match the water temp.
