Gas in oil-1995 Wellcraft (5.7 L Mercruiser) 322 hours
Todd4n
When I changed the oil before Winter I overfilled with about a half court or less. Well I planned on taking some out in the spring however I did not deal with it until about a week ago(put 20 hours on the boat). The dipstick defenetly showed oil levels above the full mark.
Okay so I pumped some oil out to get just below the full mark on the dipstick. I smelled the dipstick, the oil I pumped out, and down the one of the valve covers where the oil fill cap is. All of those location smelled like gasoline. The motor is starting and running great.
I would appreciate some feedback on how to resolve the issue.
Do I need to replace the fuel pump?
Is there gas in my oil because I overfilled with oil and put 20 hours on it this way?
Don S
Re: Gas in oil-1995 Wellcraft (5.7 L Mercruiser) 322 hours
It's very possible the fuel pump is leaking into the crankcase. It won't affect the running of the engine with just a small leak, unless the gas in the pan ignites, then it get exciting.
