Bt Doctur
Thread starter- Joined
- Aug 29, 2004
- 19,566
In case you ever run into a fuel starvation issue confirmed to the tank feed before pumping the tank check here.
You will find a fine ,removable, SS screen right here.. Remove the anti-syphon, probe with a thin flexible wire/plastic wire.
If it goes 4 inches and then stops you found it. Brought to you by the same people who put black paint inside the cool fuel pump bodies ,the tube unscrews from the fitting revealing the SS screen , lift out and throw away
