gauges help
spacerust
i just recently got a flats boat and she has gauges on her. water, speed, tach, voltage. i don't think they are accurate. the water pressure is always around 2 to 4 psi, the mpg doens't move and the tach is at around 2000rpm when off. can i reset the tach to zero and go from there? if so, how? can these gauges be repaired or cleaned out. the wiring looks fine, no breaks or cracks.
stevewolverton
Re: gauges help
Does the tach reset when the motor is running? What size motor?
As for the water pressure gauge - it's always 2-4psi? It should increase with rpm's. 2-4 would be idle pressure. Mine goes up to 25psi or so around 4500 rpm's. I would check to pitot hose to make sure it's not plugged. Is the motor running hot? How's the impeller?
Steve
spacerust
Re: gauges help
i checked the sensor hose last night and it looked clogged. I cleaned it out. hopefully this should take care of it. the impeller i just changed out last weekend and the she runs fine. when running i can still touch her.
the tach i don't know if she resets when running i didn't check that. should it?
Re: gauges help
Ayuh,.......
Many Tachs set at an elevated #,... til you Start the motor......
Silvertip
Honorary Supreme Mariner
Re: gauges help
The instant you turn the key to ON (not START), the tach should set to zero because the engine is running at -- well -- zero rpm. When you start it the tach should read whatever the idle rpm is for your motor but very likely in the 650 - 750 rpm range. As you advance the throttle the rpm should rise accordingly. At wide open throttle it should show 5500 rpm, give or take a little depending on how the boat is propped and what engine you have. Water pressure and speedometer are water pressure driven so check both hoses for clogs or kinks.
