Gearbox Problems
bream master
Gday everyone its been an awfully long time since posts........Whilst on the water i noticed a donk coming from my gearbox at low rpm,then another donk and another assuming that the clutch dog needed replacing.....couple of days later i took it in and had forward gear and reverse gear and cluth dog changed as well as a full seal kit.....Came time to put the boat in the water and Donk then donk again,so i decided to give it a little and see what happens....it got worse so decided to call it a day....i am bedazzled to what this problem may be because it goes in and out of forward and reverse perfectly,its like she wants to engage but needs that little bit more,i dont no................Any suggestions would be appreciated...CHEERS..:)
Haffiman
Re: Gearbox Problems
Disconnect the shift cable at the engine, shift into forward and do a test under load.
If OK, either your shift rod or cable is not correct adjusted or not enough stroke in the cable/remote.
royal0014
Would help alot to know what you're working on........
bream master
Sorry fellas....yes the motor is a 35hp model (35el78r).....as stated i hve no probs with the engine shifting in reverse neautral or forward under load,it just feels like it wants to engage but keeps on slipping that 1 tooth.........I was wondering whether or not i should remove the cable on the shift lever and try to do it manually on the water and c what happens..........any other ideas wld b of great help...........CHEERS...:)
Haffiman
I mentioned that suggestion above.
However:
1: check that the shift lever on engine where cable is attached is vertical when in neutral.
2: Check that when the gear case is in neutral (balls in prop shafts are in the dents in the clutch dog)
it lines up with the neutral position of #42 in below link. If not, lower shift rod has to be adjusted.
http://www.marineengine.com/parts/j...cturer=Johnson&section=Cylinder+And+Crankcase
