Re: getting out of the hole problems
i will repeat what i said before.
i say probably all the above, plus you have 750 lbs in people 300 lbs in motor, bass style boat with seats set more to the stern. the boat is just plain tail heavy. you have to balance the load. that is what you did when you moved forward. a set of smart tabs, will help with the planing. i also suggest with that vintage boat to check for waterlogged foam. foam can hold as much as 5-700 lbs of water.
your motor height is fine, that short step will not effect it.
the tilt pin postion is critical, in getting out of the hole, the closer to the transom, it pushes the bow down, farther away the prop pushes the bow up. thus excessive bow rise. bass boat are not great at balancing the weight load, you have to get weight to the bow, to help bring the bow down.
__________________
