Re: Gimbal bearing install gone bad?
This whole thread is getting confused, and I think you are too! You have a gimbal bearing which means that it is ball bearing assembly that is free to move inside of the outer bearing housing. This facilitates the alignment of the bearing with the opening in the coupler. What it does is support the driveshaft and maintains its alignment with the engine coupler. That is all it does, and you can move the bearing with the alignment tool so that it is pointed directly at the coupler opening.
