GA_Boater
- Joined
- May 24, 2011
- 49,038
Re: Gimbal bearing install gone bad?
If you're like me, if I see a zerk fitting it's gonna get grease shot into it. If it won't take grease, I'll be tearing things apart to find out why. Also using a high pressure grease gun may deform the gimbal part of the bearing and damage the bearing.
.Its a perma-lube bearing...so I don't have to worry about aligning it with the grease hole.....I did find it interesting that they include grease passage plug retrofit....so basically they want you to remove the grease zert and put a plug in its place....Not sure I want to do that..what if I don't have a perma-lube Gimabal the next time I change Gimbals.... is there a reason to put the plug in place of the grease zert?
