Thank u for the info i ended u i ended up cutting mine offHad the same issue I tackled this morning on a Volvo Penta SX-M. Took a few hours, used my bearing puller, PB blaster, and heat to get it off. My work bench also helped give me some leverage. See attached pics.
No problem, I think this is the first time this one was ever changed, 20 years old. Fun weekend project!Thank u for the info i ended u i ended up cutting mine off
Thanks for the tip, I’ll be sure to do this when I reinstall my outdrive this weekend.When you install the drive: the o-rings on the
shaft need grease but grease them after they
get put on the shaft.
Grease under the o-ring can lift the o-ring and
can make it hard to install.
