Glen-L WB Power Skiff Build
zool
Thanks for the encouragement guys, I only had a few hrs to work on the boat today, so I basically fiddled with things, did a few mockups, and stared alot ;)
I did work out the stain color thing, I dug around in the paint closet and found some minwax bombay mahogany stain and poly mix, tried it on a bare piece of oak and it was just ok, then I tried it over the cognac and it was nice!. So I think 2 coats of cognac, and 4 coats of the bombay should do it.
This is 2 coats of cognac and 2 coats of bombay.
y4m4U9SoeK4BbbLjfADwgX2s2aeRCURTtPLV9yeKs2yz3-LFvL5owHSolvXmIOi6SdReH1aBTzs2i7aIH2GX90m8RM5QTvGM3dVkmfVew6plsKDSnVuXuDYGB0HJBlp9pNXJdcY9Uj1Jf1fHreSE-8ejaaH7Bd0ZBvghpEusgTZ5lCTgMFlPMcYXph9oFv4RCaV47k0w84yx8EW53wJJLj8mw
So im thinking that mix, plus 6-10 coats of Spar should level it out nice, and give good protection.
zool
Then I set up the new pin nailer and trim router and messed with the gunnel caps. What i did was position whatever width pieces of the 1/4 oak would completely cover the curve and temporarily tacked it in place with 3/4" pins, then put a carbide trim bit in the router, and just ran it along the inner and outer hull sides...worked pretty good once I got the mojo going.
I tried to chose pieces with the straightest grain.
y4mv2pJG1ucljJ4phF5houNbdlfwIMNw9ghj5pQAzMc2J9VHNSoG9S6jXWIsB6zFN2plMZcNU1hKUH6cbisFYu2E5MYIaWDvVd4ZLqAmY4G6bYPXM-6pJ5NTFTG05MT62qw3hcAxhq9bZ2vFf-N3E32HOMskk6l4lKOLU4IQrsMzdCMfRd3b7PbbqWF5UakQNajhKufeysLDG9sPmW6RPoRoQ
y4mn6-SFKH-tQtKlcDRqckdRvem4PVx1BFlVaFnzneh9DBqrlngWVgP06oNTmMl7Dvp12xzFE1z0Lz2cme11qvnXyYSgCyQ4AWE2YyB2gzbMBk_IiJWPSiez1sUGzsm5SXakU5zK9AYWVqnaVODeUUYw23esyZkLo1tGN5ENJ2sDytdOMyNyPS8RIEBNLwe9LivhrEcYu073gkWrXTvl3wX1w
Then i just overlapped them to allow for scarfing.
y4mjDLr-SuAR__fBBeNAaCTbbDfu9cXL9x54nlYRoCGSYIQUxrwjEmGySw--nroJz9DQis3fT5mRjRFN88561Ol1LBKIcR0ov51_t_vXXZ-MqRcQ7oHug9Hi8j9chSijhyk-hGiHYbprvl2N-zAz1GEDESQ1bBuKCEPw4vlRhgiyErfpENLmnX1UMul_LtNnx8lnf72k_h5DPt4s9p26LMuNw
So that method will work out fine.
Then I took some camps and scrap and mocked up the whole gunnel cap assembly.
y4mV9pfteGMpR9W_aQFPxZ2epGOACDlymg8hLgr1GtnFP7p9f3AcuufV3YD-3T9mXSjB1WZVS3Dl4MEuskRXppBioice0UGVAJzHDlC338JZSvGjBItIn6anyQGgLpHNgipdMrkVY1YxQNaMCrdyUVLlJfOS5ZoJq8n3s4MQgVy2dOqxB-9wiKGDcIM4Wbj7nZtygEVe3_b_JJKRv5wiVBItw
y4mOrmlkT_B8_YkP8Bax8YMj5qpLcxbumw_-jzYT7O4r4I1smPaLXLUBYU_t3_SDJ4vOwK1kpqdjG0JDclWsRLB6tM8Ik5ITl1mpynK9NxkuIdiPiWO2X8-oxPiiGiDdhaSDh2uS4TJEu4fhNTucybRSTTecaR1m9--wBM91EOsttseCYboLszYSpJRw8nv8_MMUpWn2fZ-rpzOElg3SAOzHA
Now I have to figure out the spacing from bow to stern for a uniform look.
When I took it back apart, the pin ail holes were barely visible.
sphelps
Coming along nicely ! Interested in seeing how your gunna do the joints on the rails ...
zool
Coming along nicely ! Interested in seeing how your gonna do the joints on the rails ...
If u mean how im gonna attach all the pieces, I have a plan....1st im gonna glue and counter sink screw holes in the outwale, and plug them, then im gonna glue and tack the 1/4 outer inwale, then screw and glue the spacer blocks, then glue and countersink the inwale same as the outer one...all while clamped. When I sand it al, ill round oer the edges, and if I can make a jig, I may oval the spaces
The only problem I see is the rails might not support the boat when flipped, so I may flip it 1st and fir/paint the bottom, the flip it back and do the trim work...IDK....still working that out ;)
sphelps
Yes basically with the scarfing and such . Will it get a top cap over the outer assembly ? Up to the spacers ?
zool
No Sam, im just capping the center with the 1/4 to cover the plywood hull side edges...once its all glued and clamped tight, it should close most of the gaps, then maybe some filler and a ton of sanding, then a ton of varnish...On a better build, a nice vaneer over the whole cap would probably look great tho.
The scarfed joints will be tricky, im basically gonna cross cut them at 90 deg, then scarf them at 60 deg...(max on the makita)
zool
I Made a little more progress today, I filled the forward bench base with some rigid foam board, leaving a little room on the top for cleats.
y4mtt04v6D_4ExcS73BYyVdbQCEzAUAw755wAcZf249ajvn-ewKTRBx_7PsRc-ZfAk7M_6kOBkU1KxxaUZJSyC_VDO5ihQx_YIB45VBaA8Xk0vIX4pizNlVj0QjHJD-4J6jZE_-zzYI3REPc0-nyP2KhVBjZXLvSwE2sim54N_JAzNBOdUOqACAjmUZFBZsnb25ISfuKzc3ZMvB6YnnRxXG_Q
y4mzZdDWPMuZvsyluO9V2ivzi3uBjgIhuCVL9SHzAcEnBLd-O_y38rttPKiCbC2wa8Qr_ZuELz7IaRm2D0GtxsWGTrpTuE8AlFz4X5YSY5-MfBIbNxFKW5fgvFWKuVmwJzQNMbMLb-h8wflxDnChSXOrTbntBtBZNG5fKkY28kj8BS5mOJ9tOcu1oJfWAaK7laBIIWnQsA2sAYjOoxP5EP5vA
I used the cleats to keep the sides true and straight for capping.
y4m15JUBku-X1YAMYkObILAEsgz03il2D2nZq8F-92hpThSyKlyh6vGY8nICetmje92sJ2d6oHgRhWFYd_Wus27WxGr_41y6BD3mji0QKgL9tMql4E4cC0DARKK1fO2p6IDOs0hDoktEMa_2r6Sas3l5fsEISc6PECHTQfENUHy5rN4oIH5OBgguc9rz1MwUMoFG_QczOe3_7c731s9y2zhCA
y4mt0UIA4XEqzyXaSMI129Uz9O6qY3rWpFl4Bnur27neYO7UY0kI1nhViB4k6s28jfkZk60JPvCPNy-E8NnYjbA9jvMcKtEEtcCXwH4xntSmxDAA_h85dTyvIiCfwPNaQUlmApiMcoklLHyMqiYkTk2S72y2ywVu6pdVNM9fszq9wNkpJHAEEdSuofuLe4-YsqJggMEOmk206iZkBcvof0fdQ
I ripped some mdo to fit the base and screwed into the cleats.
y4mJUpW5BrRKLgxUXBLUysU4FyibbyNESKjXNg4L-kJe14cMWFDIbi80TUvEhqt-p_SquSUSGrbJaqeeNAA8pQE9LdRa4fLkJG-6jfoz24tOoPUPzriqUyqZ-bFKoXPDf1QgH3DNyuWNDLnUMrSFiSO966LZToycAB8lSsMzJnj7D5nncNjum8_2HfgLvj8_0fa8R6ghoSx07wk9ycIgBD2bQ
I have to thicken some resin and cove it in, and maybe wrap it all in cloth for good measure.
zool
Update:
I installed the outer transom planking today, I had to do this now so I can fair the outer hull and it ties into the sides.
I pre-cut all the pieces and temporarily pinned them in place a little oversized to be trimmed. Then took them apart, spread on some thickened resin and reattached them.
y4mUnHpW9ynAC-IqF8K677zeTplkE5eR7zbsqZrt1jQkLPa5hfUFZtek7v7smZiAI-5mmUb381nmBBXA4-IooziMJiLKsYaUUcHSi9kppmwcpsdweZXTQRUmUB7uXmz2kXDZJE-BFarGe37_h4aNFdaoA-_KD4z2329TiRX9GclfcnMZw3HicKkYgaRbX7XpWCW5GordRPfox3fLAb3hFjrRg
Then I strapped the boat up to flip it.
y4mUiElRr-EZK0mPhqEKXGnReQBnIWRT4ppAXKZ5rHy8FLpNiugde-WVrt1wvxfaV-tlQftOd7mDcFWHELA3BmGTHuqk6Vv0JUTflhvRKrMVF68MaZdM9HeyCoV-NMdPrVPcTRiDjP-YiI62nQo-bMBeYknto14hGK3U0S8dkhztSSZ_WEZvLtZwHyA6XvtYtG5Mya1HJSC8SXOymKsn1nqGw
y4mVIqJpB977X44pb6ip1QYodBg264u5n-b57ReSZHYpqsEV1ZwlJ1Bc_gKbmloAqcpkGCOLyEjZkGil-d3ac8c32CVna57qXNSeoh4Gq20UsqBt-cozrf8cU10t6VobqJl4sr7E-qWTul-bMsN4J6wgzm-9FyOqXGdQ-DvAReXYr8jJVZuzATeDK8hpkgkrATVX5vM5t8d-d_2KuXXpPzzkQ
y4mD_R-JzSxEXRxmkj0wX1XIBaHTDXDb-RtC_zJXpjPhVuXFWpH1uasHHmMgrAM8u4bq0ihUX_2p0W3ZkQGT4ACL7Ki8KToxkaMj3ht9KbI2GfKvwecG6wlKf8DNP5pN8bJPS2CBfhOwxfPmf61XEeh4pPzmTfzuenxi6MT7AsYdn9nPhDkz0tUxVnEGGlqODJdXkzGttsgYv4QtXri6qycKQ
Now that its back over, I can finish fairing the bottom and sides, and get some paint on them. The bottom and boot stripe will be oyster white, the sides will be hunter green, and the transom will be stained and varnished.
