Glen-L WB Power Skiff Build
zool
Have you ever tried rubbing on Udder Balm from a farm store? That stuff dose amazing things
I have a prescription cream that works like that, but thanks, you jarred my memory, it was "invisible gloves" that was recommended, you coat your hands with it, and it closes the pores and keeps everything out, then just wash off with water when done working.....gonna order some and try it.
saginawbayboater
Zool you gotta take care of those hands man they lookin pretty crusty! Ouch! Skiff is awesome following for sure, and the pine walls and cabinets are beautiful following thos as well!! :thumb:
mickyryan
poly don't do that sam, lots of folks find out they are allergic to certain epoxys over time, i have read stories, i like the smell of poly resin in the morning :) one of the plus to epoxy is low odor or for brits...odour :)
kcassells
Vaseline may do the trick also. I use it when I'm messing with adhesive sprays and stops the stick.
zool
Thanks saginaw, I finished building and hanging 28' of wall cabinets, and started building 50' of base workbenches, which will be filled with drawers and doors. Also got the router table sunk in.
y4m4inmF5PyQGES1X0QNmYNE-TqEScnkIFvDDjybM8stkMGTXcsW0mmDgNSfQDmnt4EwCxXUMPWjFZQG4EXmjq51Ra8ljAe5yqy4VlpCiMUz5u40cYc8W9abVwNTh7DJOzF_0rWTxHCzocD1OxGMkheeUSZszqsCBGlIqNgJ6bZ1B6wL-FKhs_RE-gVXBg6_EezXF9J9pGgbWSreYIZzYIflQ
y4mk9bmFowq8UfDCPJowP7lt53thpg88scArHWZPPBmvCVw6SStmJwjV5239zBl28Kz4jpaBt8yjz7z3Wh7DgDBiQ7dZ66b3AYmU_SywtHEXtsnyzodABs8Fs4SZo6aET9HT-k2pptXsngqFLvoQVztf8_IJwnm5Vktzb9y7AgNeIrBW8X9KCSgn2Apb4iHqVEYLgC3yyF0yueAEvRYfJ2lKg
y4maJg1z1XpChEDugduioQ3X_ffv7ShF9SazRt9WgVlt0Lp3PW6sI9agmKgLusV7C98h_fsRsFEnSIgULlv4otXDtWbeBnCBmPfOF7nRhVVxh4N-Zbqv64lv9clc075NQTGQSa6h2qebi85Swum-R9JejBFf5xFr6DguTE5AH3TP9lV17dhd79yHcNAz-2ETxa0o_OErLi60GczEEkpakOmhg
y4mFh1NGhOnJjXtjAY26k_O_X4eYQwMSMdxcNyaDHwmqWVvVnrXTQJdRDyjxh3jg1eX0ZPptK9iDLF_IS5m2i30kLZf1bJB-i86IVAssydT4bObvut2VIV4_MSAYgsJ_T-OK3VTmlr6HU7nO0wqv2sCh-NtHfgRjVPNyeYtar-nxDwLQtK3d6wt6nMkpHQpo6PSZr9YYaMJtIm_2oDtSW3Sug
Hands are almost back to normal, so I can screw them back up again this week and hopefully get the sanding done.
Pcolafisher
Have you tried the arm length plastic gloves like veterinarians use? I use them slipped into nitrile gloves to do my field dressing. Worth a shot to avoid the evil rash!
Cheers
sphelps
Holy smokes look at all those places misplace your tools !
‘Outstanding start to the work shop !
zool
Have you tried the arm length plastic gloves like veterinarians use? I use them gloves slipped into nitrile gloves to do my field dressing. Worth a shot to avoid the evil rash!
Cheers
Thanks guys, pcola, I had some success with long ansell chem gloves and may go back to them, with the invisible gloves underneath. Im reading the acetone may be causing the hardener ingredients to penetrate the skin, so im gonna try cleanup with soap/water.
archbuilder
You are making me feel lazy Zool....I need to do a bunch cabinet building. Looks great!
zool
Thanks Arch, I have 4 immediate things on the to do list, patch the metal roof in the cold, jack hammer out all the concrete curbing, sand and fair the hull, or build cabinets with instant gratification lol....I have 50 more feet of base to build, and 15' of wall cabinets to build yet. Gonna jump back to the boat this week and get past this segment tho.
kcassells
Larry,
I'll come over one night. You climb up on the roof with a spotlight and I'll mark the holes below.:faint2:
And yip yip....lookin real nice there.
AShipShow
Don't mess up your order of those.... Patch the cabinets, sand and fair the curbing, build the concrete, and jackhammer the hull... :laugh:
zool
Larry,
Nah, you're too nice a guy to have marking all those holes, ill just let u go on the roof, and ill do all the beer drinking....I mean marking work!......did I mention u need a harness and rope to go up there? :D
zool
Update:
Got the whole hull sanded
y4mCkeafQYjEbrhA6lr3Xy3JNzfmFCV0C-gykejvDXlKys2CdeHUy71novKWX2JYYfadU4xMDLCs5XbSySv8JK6kBYIoomggHdZpmmP__pEBt1tcKe5phM40e5n3XF63C--M4FYsqs5rOpuQSABBHP6OSDQVvaRfsGFNo-SigPFy3wEmU-iL4XfTv3lGlp9A9HwZZa_TFsWCD4AS679l1ggSg
y4m-WJu1lfqjWhC6Sgbhl6s3-w2MqJfB0FO47Iy-ReeR4lHWoBQp2-Bz8hW_u7CrDMTfkRflqMT5xqeuH1YDpWU79NYTfQgoLC3Hzm7AFIu79bDA9dmDCibSYwa0Y8KCEWZAWQf4gsNjpE_a_c5QQlN1Tn9V3nU3EFQCjrMyisaEcPTyHUb3FaIRjiYlF0NSOfcxIDxg4y3crYCCjo9HT-RAg
y4msAXnHButb08_15AtvYjedEHYBFwxxhMfN4f_VgKx_xyBfCUK7iPh_jf98-Xl_A1WDIhC5RMnekUqOTEDzLY_kKNs6Jmr9mKEr7x_0Ncr-Q8nhFnjCszjdxQKr8x5tpXocgsRXQrl4d_CJY6TTk2e-WDE68vUOOWcrEY32Tt7VSGlWMprVMeMGox9JVCwzK8OGPtxhgyow8uz4rLFFIp3DA
Taped off the transom planks and got a skim coat on the bottom to fl n the valleys.
y4mj0pvJENn4Uq7JtQh3aYSEYVwsjN8MFiYve1DPZuIFlNRsnVgMfwoaavC1wCpRavy6QCEsH0ghcAz29-1k4OrkuzJ4aO6RdmTheh6_pV1NWnMwpPW5lAu8drHz4C8Didai1lh9x8YqrCvRtJJfrESRNdMwzILiAx2vQh08WfZyHQOKwHeNU3YrRVo8HhPEbhWNiMVrMV4CCxF4WVeJ7Fc9A
y4mRQUCfNInkMuyku8st2V_7e8_FlVpBpEcG4A-xNHE3UZ6h90Hi1Sok0IAmTRqe7ABuzPTCN1ufuiY-yOW1lvXnRK3F2GwLg1QGQpkFOfEDrexnCpJi87noGkpDWRuJTttW0rBI6IjVJffEYMX_3AqMwUivcAmSxqyE-XqWOk-cNYBFzcK6fcvhgldOgM4qlT4FrVoWFZQCKfb5BR2D6AxPA
Ill get some putty on the sides after I finish a few other chores ;)
zool
Also got the cabinets built and hung for the other side
y4mPJbpjJ5bFrQHck_MfsutAuhr4FdLDWG1itPvBIPQ4CJk-DLb8wr9qtWxP1b76f6_ssoDNjv6PkCtwf7tUbOyMbxaTwsuNO3c4f2DDMwiiD6uPdzmpY-qhIK8zdCZNLrQp8MuO4yGqxRBEJifgnWXMZbhIR-4Y63l0kU85xfGXKL7vzM6LQ65T2r34c_gxYZ9F7pGMu-sSRnGc3efD_Xw3Q
Framed the lower sections too.
Left spaces to recess the machines.
Space for a flush mounted spindle sander (Rigid)
y4m8RkHW4NQqw7K_Fc_kPZHgyOCTNeQyP9d1fu_wTTdZXxHmzX2UmuKk5FGbLlI6XGBJtN_rv6Esu8mShKi6HJHpDa4i_hQPBAbrbTCWE42ORbPH-91V9BMN1oM1qOl0cUbOTuznaujAjpR5hTJwP30QK6p-uZNuo5wS6Sh2lylCPEWZAT-cBKTyNMCyZyDWfgYxyqDdTEvivY2boiLsj6JEA
Space for flush planer (Dewalt 735)
y4mdoEl9cp1_jur1ElfUW3G_NQDVcute2KZGQ5WPyBHKY-opnX4dSKaFxKILS0RltKlIM1o_AvwA2YLHKhTswNqbbPkn33H2E8e0ni-OYAdMlBV_k-f7lB9R8KUhcjTBaS3CKS6tnwPZ02eEufDgqwZ4hK-bdymdOihhyJ95MnfawEYII0OBn6w5vmqpaIYtoQDaEg8rZG-tlVpSscMrQffHw
Space for flush Jointer (Cutech 6")
y4mm6MGpVOo0DURmyVGHh-XFVaO3T6djRbAc4PQNplZBQHdctFv8I8_LB-e6r-S7a1Z9F6aKvIaXND4EBa2ioKnGQ37ob6H0yRvUFPiCtyEeGjmOE_a9H7Yitk-irNJH7xfWzBTeTI2vqzRfz54IGkqn5tG5FOI7iGZheg4zMjdCBGkPbJ86b4WO1kQzNNXwk55oEplMPlEdTCviyhjVhSlcQ
Tomorrow get rid of the curbing.
