Going thru drive
midnightrider1818
One more question the bottom base gasket should I use any perfect seal on that or does that go on dry also too
achris
More fish than mountain goat
You have an MR/Alpha One lower unit, so no pre-load pin. The pinion and forward and reverse push apart under load, hence the way the top drive shaft bearing is set up. To check the bearing, pull up on the shaft and turn it... It should feel smooth and tight...
Gaskets go on dry...
Chris...
midnightrider1818
Drive update ok got new water pocket cover on and new pump assembly. I'm ready to attach the top to the bottom. Any hints on doing this. I'll be doing it by myself. I have the shift shaft full clockwise and got the prop locked and bungeed ccw. Got new oil seal o ring on also. Just one more question on the shift shaft all I have is a stainless steel washer. Thought I read somewhere there is suppose ti be a rubber washer also.
midnightrider1818
Well sh&& I tore the spline seal putting upper on lower. Harder then it looks. I have a hard time getting water pipe in guide. May get help for this.
It does happen to the best, I find it easiest to turn drive up side down, then put the bottom into the top half
achris
Haha... I do that when I split the Gen IIs. Stops oil dropping everywhere...
Chris....
midnightrider1818
Ok update. Got drive back together. I'm wanting to repaint the gasket surface on drive. Question is I bought rattlecan primer and paint. I was wanting to brush it on though. Good or bad idea. Could I take the primer and paint and spray it in a cup or something so I could brush it on. Anybody ever do this
achris
Why not just mask off the areas you don't want to paint?
Too simple?
Chris... ;)
