Re: Goodyear SeaBee
No seal in the pump housing.
The reeds screws are supposed to be sealed. But the tiny bit of leakage won't amount to any performance loss. What does matter is if one of the screws comes out. You can then kiss the whole thing goodby.
Another caution: The hex bolts that hold the gas tank bracket--if they are too long or you leave out any washers, the bolt goes in too deep and hits the reed plate flange, bending it. Then it leaks badly.
Been going thru the SeaBee last week or so everythings looking good; powerhead is clean and in good shape, ignition parts are pretty new, went thru the lower end last night( in good shape with no issues) pretty simple lower end.
The only question on the leg is for the waterpump housing, it dose not appear to have a seal in the upper housing to driveshaft? Still need to clean carb body and reassemble with the gasket I made, and clean fuel tank then reassemble motor. One more question, on the carb body where the reed plates mount to body do I have to seal the threaded holes on the outside?
In many of the pics I have seen of other carbs for this motor you can clearly see a sealer of some type ( also mine was sealed too).Landscaping wiz & Ohm116 you guys still around? Did you guys get them motors runnin'? I would like to hear how you both have done. Thanks to all who have given advice so far.
Talk to ya later. Larry
