Joe Reeves
- Joined
- Feb 24, 2002
- 13,262
Re: Got her out of the garage...nothing.
Did you check that fuse yet?
I checked one fuse yesterday. It was a smaller fuse. See on the picture where the 2 is, to the very right of that, there's a rope of wires in black tape. A black wire comes out of that, has the rubber boot plug with a fuse in it, and then the wire goes back into the tape. Looked at it, looked fine. How do you tell a busted fuse? Should be charred or at least the lead is fractured, right?Did you check that fuse yet?
By "tenuous" connection, do you mean the connection where it eventually may have failed?check the connections at the key switch also. A bad connection will often times click like you said then stop at the tenuous connection it had failed. I think you just have bad connections. If it ran last year it is not wired wrong. Take each connection off one at a time clean it and replace it. That way you don't get any wires crossed.
I get different readings based on if I ground my meter to the motor ground or battery ground.
Thanks again for bearing with me. I appreciate all of the help.
Is there a conventional location where the motor to ground usually exits the motor so I could follow it back?
ps...nice avatar, what motor is that?
From there, this cable then then sould exit the motor casing and head for the battery, correct? If I follow that back with a meter I may be able to find where the bad connection may be. (?)
