Re: GPS flakes out when I restart engine
What statement?
...I disagree about your statement that a voltage sag will cause damage.
What statement?
Totally agree.If the unit has a properly designed power supply/ regulator, any spikes, transients, etc. are absorbed by the front end of the PS and not passed to the electronics. Under these conditions, the low voltage isn’t any harder on the “equipment” than hitting the power switch.
Wiring the electronics to a secondary power source is nothing more than a Band-Aid fix. It doesn’t resolve the real problem of the voltage dropping to such a low level
On the other hand, the low voltage condition can be murder on a starter.
FWIW: None of my electronics turn off when I start the motor unless my battery is severely under charged or is due for replacement.
The PS in my sounder is good 10.2 to 31.2 VDC and can be jumped to 100-230VAC, 50/60Hz. My Garmin GPS is a bit less sensitive (has never shut down) at 10.0 to 35VDC
...the GPS function won't operate after restarting the engine. I didn't mean to imply the unit shuts down completely; in fact, other than GPS functions, it continues to work fine.
If the unit has a properly designed power supply [and] regulator, any spikes [or] transients...are absorbed by the front end of the PS and not passed to the electronics. Under these conditions, the low voltage isn’t any harder on the “equipment” than hitting the power switch.
That is a great theory. What is your basis for assuming that every item of an electronic nature on all boats will conform to your theory? It is very commonly observed that many devices are intolerant of the voltage fluctuations that occur during engine starting. To insist they will be tolerant of these conditions seems to ignore the real world in favor of the imaginary world.
Further, just about all devices specify a range of operating voltage. When the supplied voltage is outside of that range, on what basis are we to assume that the device will continue to operate? Because you say it should? That seems completely unrealistic. The real world outcome is that when a device is supplied with a voltage outside of its operating range it does not operate properly. This is a simple paradigm. If you want your electronics to operate properly you just need to supply them with an operating voltage that is in the required range.
Pot....meet kettle!other than perhaps they like to argue about nonsense.
Does your GPS receiver ever work at all when the engine on running?
This is what happens:
1. Unit is on and GPS and fishfinder functions work as intended.
2. Boat engine turned off. Unit continues to function correctly.
3. Boat engine is restarted. Engine starts easily on first try with minimal cranking.
4. Unit is still powered on and fishfinder works. GPS does not work; speedo readout is frozen, map on display won't update position.
5. Power down unit (using on-off switch on unit), restart it, and everything works again.
Pot....meet kettle!
Fixed it for you!The only comments I have made which might be considered argumentative[all] were to point out that others have invented remarks[you], attributed them to me, and then offered some rebuttal[with yourself]. They are arguing with themselves[yourself]. That is nonsensical[definitely you].
Believe me, there is no effect on the Global Positioning System when you start your outboard engine. It's up in space and it does not "flake out."
Fixed it for you!
Your comments are becoming more off-topic and nonsensical. You should limit your replies to the topic under discussion. You seem to be inclined to make other participants the topic of your comments. The forum would be better served if you limited your remarks to the technical topics and stopped your intrusion into these discussions to talk about the participants instead of the topic.
