grommet sleeve
gpmike02
Why does it say not to use #16 on 60 degree motors? I have a 2001 johnson 115 and when i pulled mine apart it didn't have that grommet, so i put it back together the same way, but just curious as to why its not used on some and used on others.
oldboat1
Is your 115 a 20" model? (thinking maybe the 60 degree model didn't come with a 20" shaft?)
????---- Lots of the 60 degree V-4 motors left the factory made for a 20" transom !!!
Faztbullet
This is a late model DI engine part...added to kit to make em more universal I suppose.
gpmike02
yes, mine is a 20" shaft. I was just curious as to what was different between the 60 and 90 degree motors for the 60 degree motors to not use them.
flyingscott
The 90 deg crossflow is an entirely different motor than the 60 degree looper.
Motors are not ---" all the same "-----The 25" V-4 and V-6 use a different lower unit as an example.----Perhaps a different midsection / exhaust housing too..----
