- Joined
- Mar 8, 2009
- 43,648
Been thinking about this and I think I have a better idea, and should be real safe to do. The original Tank has 3 holes which work fine. Its the other 2 holes that's causing the issue.
What about a small piece made up just to under the lip of the tank sender hole? Cut drill then and tap the holes. Use longer screws on those 2 so they will be easier to start in the piece of stock.
Use some adhesive and insert the piece inside the tank hole and up against the under side. Adhesive doesn't need to be permanent, just hold if enough so you can slide the sender in and get the 2 screws started.
Once the 2 have been started and gasket is on top, your home free. If the adhesive gives out its of no issue because the 2 screws will hold and allow it to be tightened. The shinny spot not quite all the way thru will need to be opened up so screw will go thru and into plate behind it
