I want to lower the outboard on my boat, Johnson 115, on a 64 Johnson Trihull, but there is these metal shim's there, and the hooks on the outboard wont go over the transom due to the thickness of these shims? They were on the boat when I got it with and older Johnson 115, so I just left them there when I put this engine on.
The reason I want to lower the engine is because in turns I get pretty good prop slip if I don't back out of the throttle quite a bit.
Thanks
http://i278.photobucket.com/albums/kk107/parrisw/P1020282.jpg
Thanks
