trying to remove a belly tank from a 1974 center console. The tank was surrounded by foam, but I have cut out and remove all of the foam that I can possibly get too. There's still probably foam underneath the tank and I think that is what has the tank stuck in the box. anybody have any ideas for getting the tank unstuck? Chemicals that would dissolve the foam. Some trick with a tool that will get it out. We've already tried putting a hoist bolt through the sending unit hole. That did not work at all.
