Help! I need help on 470 outdrive !!
KCKracker
i want to order a kit to change seals , bellows etc in my gimbal housing but parts store has no clue what kit i need. the parts store says it will be decided which kit depending on seal size, then he said it depending ONLY on what my motor is :facepalm: . website says it depends on if i have a bellows exhaust tube or straight.
i dont know who is right?? im looking at these 2 kits http://www.sterndrive.info/sterndriveparts/transom_service_kits.html
i have a straight exhaust tube that doesnt connect like the lower picture but parts guy says according to my housing # thats wrong, but right for my outdrive. im lost!
Re: Help! I need help on 470 outdrive !!
Ayuh,... What Vintage is it,..??
Is it an MC-1 drive, or Alpha 1 drive...
Bellows or boot is a personal preference more than anything as they're interchangeable...
KCKracker
drive says "470 alpha one one" on it.
KCKracker
oh and so the exhaust outlet is preference? so i can make this come out of the outdrive/prop instead of the gimbal housing by switching to the bellows? also, i saw on a youtube video they were using a glue/adhesive in the boots before install, is this a good idea?
KCKracker
thanks dubs, its downloaing, does that cover the gimbal housing etc?
KCKracker
i want to order a kit to change seals , bellows etc in my gimbal housing but parts store has no clue what kit i need. the parts store says it will be decided which kit depending on seal size, then he said it depending ONLY on what my motor is :facepalm: . website says it depends on if i have a bellows exhaust tube or straight. !
anyone?
dubs283
you have the answer in your question
you have a 470 motor
you now know you have an alpha drive
bond-o cleared you up on the exhaust bellows/tube
what other question do you have??
