help identify old motor
Status
Not open for further replies.
earlybird
Help!!! Recently bought old outboard, has no ID plate on it, is single 2 1/8 diameter piston 2-cycle w/ egg shaped fuel tank wraped around magneto, pull rope wraps around top of mag and comes off after pulling, is water-cooled, has Eisemann Magneto Corp,Brooklyn,NY w/Model #61-M and Serial #47-B stamped on bottom of magneto, cast iron cylinder body w/#463 on left side and #1881 stamped on right side, # inside lower unit is 63-310 and # 463-3102 on lower unit cover, carborater has cork float w/Tillotson, Toledo, Ohio stamped on top of fuel bowl w/ # AJ16A stamped on side. Appreciate any help in identifing make,year, and horsepower of motor
corm
Re: help identify old motor
Hi earlybird,<br />Hope this doesn't sound dumb,but if it is painted what is the orignal color? Does it have a seperate exhast tube going down to the water?<br />...have fun...corm
earlybird
Originally posted by corm:<br />Hi earlybird,<br />Hope this doesn't sound dumb,but if it is painted what is the orignal color? Does it have a seperate exhast tube going down to the water?<br />...have fun...corm
edwhitson1
You have a 1946 3.6hp Firestone outboard motor built by scott-atwater. I know the year from the 46 in 463 on the cast iron power head, i have one exactly like it, same year, and same tillotson carb.
edwhitson1
Not sure about his but mine is silver with red Firestone lettering on the font above the throttle, and no there is no tube that goes to the lower unit. both the exaust and water pickup are hollowed path ways in the motors lower unit.
Bob_VT
Well............ since this thread is almost 12 years old :facepalm:
We have some guidelines here. Threads older than 90 days are normally left in the archives and not commented on unless you are the Original Poster.
This one is going to be closed. Thanks for the input!
Status
