GoldDuster360
- Joined
- Feb 2, 2015
- 110
Hi guys,
I have a 1983 Sylvan Super Sportster 16V (StarCraft Super Sport), modified V, 5% or less deadrise at the transom. Boat weighs approximately 1,400lbs fully loaded with people and gear. It has a 1983 Mercury 70 3cyl (no power trim or tilt), with a 10-3/8 X 13 pitch aluminum propeller, Quicksiver, has small nicks on all three blades closest to hub and very little cupping on outer edges is present, very minimal wear/damage to blade tips, would rate prop at 90% to a new one, no vibrations. Engine is in excellent tune with recent spark plug change and is propped per the engine chart in the manual which suggested 29-35mph performance.
Holeshot and planes satisfactory and at full throttle will do 34mph (GPS) at 5750rpm when fully loaded. Cruises nicely at 3850 to 4,000rpm, around 18-20 knots. Boat operates satisfactory and am tempted to buy a new Quicksilver prop and use the old one as a spare, boat works ok as is but there must be room for improvement.
Only issues are the prop occasionally ventilates or breaks loose momentarily when crossing wakes or if there is allot of wind. Nothing bad but would require manually moving engine down one notch to prevent it which usually causes it to plant the bow down a bit more than we would like. From what I have read so far, an aggressively cupped prop might reduce this.
Because of the manual tilt deal we sometimes get a little close to the bottom when looking for a place to anchor, manually lifting is a pain so sometimes we kick up a little sand, not enough to really damage anything at idle but it seems like a good idea to have a stainless prop for a little more abrasion protection and hopefully pick up some economy/performance with the thinner blades.
Based on above, what stainless prop and pitch would be a good replacement for my aluminum one? Engine Max RPM range given in the manual says 5300-5800. What isolators (rubex, mercury, etc.) provide the smoothest shift into gear with a heavier prop and provide strike protection for the lower unit due to stronger stainless propeller? I am looking at a Stilletto in the same pitch and diameter but suspect if aggressively cupped may require a notch down in pitch. This is my first boat and have tried to get a good handle on everything but I could use some advice from the experts before laying out some more greenbacks into my hole in the water.
Thank you in advance,
Bob/Goldduster360
Bob/Goldduster360
