Help me to re-ring my engine.
crispins
After much research and a few different threads here I believe that re-ringing my motor makes the most sense.
I want to use this thread to help me to get this motor pulled, tore apart, fixed, reinstalled, and adjusted.
Here is some information.
The boat is a 1996 Sunbird Sizzle 14' Jetboat with an OMC 115 turbojet
The hull and interior is in very good shape.
The boat was last tagged in 2013
I paid $1,500 for it.
Compression was between 30-90 PSI on all 4 cylinders
I pulled one head off (the easy one to get to) and the cylinders look good.
The motor spins over very smooth when turning the flywheel by hand,
Here are the pictures
My goal is to get this one the lake for the 29th of this month.
I have a full set of tools and an engine hoist.
I plan on pulling the powerhead out tomorrow and disassembling it so I can get a list of parts I need to order.
How does this motor look to you?
Yes I do know that a full rebuild would be best but this is low budget tech that I need to work with.
jakedaawg
I certainly hope your set of tools contains an oem manual. If so, ask away.
ondarvr
It's really not worth it to just put new rings in, if you take it apart you should do it all while you're in there.
​If 30 PSI is correct, there would be some serious damage or wear, which means boring it oversized and all new pistons and rings, and going that far means you should replace all wear items, It would be a complete rebuild.
77kingfisher
Is it safe to assume its a 2 stroke? If so have you tried a de-carb yet they might just be stuck and need to be freed up that's a super low budget repair. And even if it dosen't fix it "enough" it will make disassembly a hell of a lot easier.
crispins
yes 2 stroke.
What is this decarb? Is it worth trying?
crispins
Can you explain a little further?
The pictures I posted were of just one side of the motor. That is the side that has 90 PSI, the other side had the 30 and 60 PSI.
The cylinders on this side look pretty good to my eyes.
jakedaawg
Pull the other head off before you bother pulling the motor. These little jet boats are a pain...might get lucky and just have a blown head gasket. This is assuming your compression guage was installed correctly and is of decent quality.
175se
Whats that stuff next to the pillow in the cyl head?
crispins
The compression gauge is an "autozone rental" so not sure of the quality.
I will pull the other head tomorrow, it is not as easy to get to. I am also hoping that it is a bad gasket on that side.
jakedaawg
It's easier to pull the head than to install the powerhead on some of these little jet boats.
Honorary Supreme Mariner
I do not believe you are going to make the deadline of May 29.-----As i have stated before you need to take this apart.---Measure the parts.---Decide on a fix.-I have pulled the engine out of my " Fling " jet boat.---Have a good idea what needs to be done !!
crispins
how does the head gasket look on that head?
Does it look like it was sealing correctly?
Also how do I connect the engine hoist to the motor to remove the head?
Do I need to order an eye that connects where the flywheel nut goes?
interalian
Get an harmonic balancer puller and some suitably long 5/16" UNF bolts. Leave the flywheel nut in place, snug the puller's center bolt down, wrap a chain through the puller and lift.
crispins
What is the best way to remove those gaskets?
I do not want to scratch up the finish.
crispins
Perfect thank you!
