After much research and a few different threads here I believe that re-ringing my motor makes the most sense.
I want to use this thread to help me to get this motor pulled, tore apart, fixed, reinstalled, and adjusted.
Here is some information.
The boat is a 1996 Sunbird Sizzle 14' Jetboat with an OMC 115 turbojet
The hull and interior is in very good shape.
The boat was last tagged in 2013
I paid $1,500 for it.
Compression was between 30-90 PSI on all 4 cylinders
I pulled one head off (the easy one to get to) and the cylinders look good.
The motor spins over very smooth when turning the flywheel by hand,
Here are the pictures
My goal is to get this one the lake for the 29th of this month.
I have a full set of tools and an engine hoist.
I plan on pulling the powerhead out tomorrow and disassembling it so I can get a list of parts I need to order.
How does this motor look to you?
Yes I do know that a full rebuild would be best but this is low budget tech that I need to work with.
