Re: Help! Mechanic says need 2nd Pwrhd in 1 mo.
G'day. As a mechanic myself, and the first to run to the defence of outboard repairers I can only say the it looks like your Mechanic has stuffed up. The Yam has a warning system to show when the oil is low, so I reckon that this is not the problem. Maybe tha mechanic did not bleed the oiling system when the motor was reassemble.<br />What was the failure with your first powerhead, It is no good replacing a powerhead if you do not fix the cause of the first failure.<br />The oil feed lines on the Yam can get blocked causing oil starvation to one cylinder, were the oil lines cleaned out before re asssembly.<br />80 Psi sounds low but I am not a Yam expert<br />Contact Yam and tell them about your problem, do not go back to your old repairer, ask Yam if they know about a good alternative repairer in your area, get the alternative repairer to give a report on the motor and then return to the first guy with a copy of the report, do not get agro with your first repairer but explain the facts. If you discuss the problem as mature adults then I am sure that your problem can be solved. Good luck
