brickbardo
- Joined
- Jul 2, 2010
- 3
I just got a Nissan NS70A2 and things were working fine until the other day when I could not get the throttle control lever to slide into forward. I checked the cable and lever, all is fine there. So I decided to inspect the problem at the motor. I removed the control cables and can manually slide the clutch arm backwards, which I assume is the reverse position, and I can easily return it to its neutral position. However I cannot slide it past neutral to its forward position. It feels locked at that neutral position with no give. Any help would be greatly appreciated!
