Re: Help! New Boat, New Boat Lift, Cable broke!
No pulleys, 4 cables on each corner with 4 almost useful Grooved Cable Winders.
Please clarify your above statement:
"4 cables on each corner"
Is way different than maybe "4 cables, one on each corner".
The Boat Lift U.S. website shows a lift like yours with the 10k capacity. That lift shows one cable at each corner coming down to the cradle (at each corner), thru a pully then back up to the cable winder.
Your pics appear to show one cable at each corner coming down from the cable winder and anchored to the cradle.
Cruise down your canal and scope out how many other 8k lifts of the same brand as yours has the same cable set-up as yours.
It is possible that the local installer used the pully brackets on the cradle to merely anchor the cable end instead of using the pully that is to be in the brackets. And then running the cable end back up to the cadble winder beams where they are to be anchored.
