Re: HELP!!! No reverse Engine Stalls
and you are sure that the prop was locked in the ccw position when you reinstalled the drive? and the shift shaft was locked in the forward position also. and that that the roller was inthe fork assembly correctly. You are gonna have to remove the drive again and make sure all the above are done correctly.
Good Luck and Happy Boating
