Re: Help stator or What?
What motor are we talking about here?? Is your tach still dead after replacing the rectifier? Did you cross the battery leads at all? How old is your battery, has it been load tested?
I would start by checking the wiring and connections, polish them until they shine. After that test the stator. Disconnect the yellow lead and yellow /gray lead at the terminal block. Connect the red meter lead to either yellow lead and meter black lead to ground to check for shorts. An infinite reading on HI ohms scale indicates the windings are good. Connect the ohmmeter on LO ohms scale between the yellow and yellow/gray. A reading of .25 ohms + or - .1 indicates the windings are good, and an infinite reading indicates the windings are open. If windings are found to have failed, the stator must be replaced.
Or if you have an ammeter, disconnect the voltage regulator at the terminal block. Run the motor at 4300 to 4600 RPM and note the ammeter reading. SIDE NOTE: Disconnect all accesories, uncontrolled voltage could damage the accesories. If the ammeter shows charge, replace regulator. If ammeter shows no charge, check rectifier and check stator windings as described in the above paragraph. The rectifier is tested with the ohmmeter on HI ohms scale. High reading on one check and low reading on the other, the diode is ok. Zero reading on both checks, diode shorted. High reading on both checks, diode open. Good luck.
