Re: Help! Twin 1990 200 Yamaha's
OK I have searched and searched and there is no trim sensors. However there is a large black box mounted under the dash beside the key switches. One for each keyswitch. What would this be for? I have also spoke with someone else at a Marina and he said to check the Amperage coming from the oil pump. He has seen it where the oil pump was drawing to many amps and prematurily(sp) failing control units. However I have done this and read only .5 A on both engines. Does any body know what should eb there? He said 2A. Ray you said a improperly installed oil sensor in the cap will cause this. I think I got it hooked up right but what do i need to look for?
