matthew55gregg55
- Joined
- Aug 1, 2010
- 7
hey i just bought a 18 hp fastwin motor. and it needs some tlc. it dose fire up on the first pull with the chock out and the throttle all the way out. is also sputters real bad every 20 seconds or so it sounds like a sneese...if i lower the throttle it will eventually conck out and will not start unless i chock it and pull the throttle back all the way. i also noticed in the drum i had it in that there was some oil in there i dont know where from...i also noticed that it will conck out if i push the chock back in...i pulled the plugs and they seemed really oiley so i cleaned them back off and stuck them back in fired it up and checked them again. they were very oiley again.... i just got it so i havent had much time to fool with it but im thinking the carbs need cleaning.. one more thing the guy who i bought it off of said it slips in an out of netural when you put it in reverse but it works fine in reverse at a low rpm.. it smokes really bad to any advice on what i need to fix?
