cptnmcluvin
Thread starter- Joined
- Jul 29, 2010
- 72
I need a little help.
Last fall I removed and took apart my Alpha One gen One outdrive. The water pump and impeller were removed at the time. I do remember the impeller was twisted in one direction with the fins bending back. I don't remember which direction.
First question: Which way should the impeller spin when It's put into back in the water pump housing?
Second question: When the lower and upper are reassembled, how do I know the upper and lower shift shafts are lined up in the forward position?
Next time I will take pictures of stuff before I take it apart.
Thanks a bunch!!
Thanks a bunch!!
