nightimefishn
- Joined
- Jul 27, 2009
- 54
Hello,
I am looking for some answers with re wiring my boat. I am planning on a 10 circuit blue sea systems fuse panel and 10 contura rocker panel switches.
Couple of questions
I have run 8 gauge marine grade wire from my secondary battery to my console. I am going to connect to the pos and neg terminals on the fuse block. Using heat shrink connectors and adhesive shrink wrap.
Do I run the accessories to the fuse panel and then the fuse panel to switch? I am having a brain fart and cannot wrap my head around it. Can someone chime in and give me some help please.
I have 8 on/off contura switches and 1 on/off/on single pole double throw for the nav/anchor lights and 1 on/off/on double pole double throw for the bilge with automatic switch.
If I run the positive and negative from the accessory directly to the fuse panel then how do I switch these accesories?
Can someone give me some pointers please.
Thanks again
Couple of questions
Thanks again
