Help
pita482
I replced the hose today on my 70hp recirculation system, the hose went from the puddle drain plate to a nipple by the bottom cyl, I was inspecting the old hose and noticed there was something in the hose when i cut the hose in half there was a small oneway valve in the hose , Can someone please tell me the way the flow goes??? From the plate to the cyl or the cyl to the plate ??? Thanks!!!!
sidenberg
Re: Help
Typically in the recirculation system, the excess fuel collects in the drain and gets sucked into the cylinder where it can burn up, so I believe your check valve should be placed to allow this to occur.
