Here are pic's of my Project
Cast-A-Way
I have a question on curved Transom (see pic's below)
Since it is not straight how can I redo it ?
I would like to do it from the inside without removing the cap if possible
Can I use thin layers and build up ?
I am ok with where the engine mount is that's pretty straight
(I know it's on OMC so be easy on me) ha ha ha
Cast-A-Way
Re: Here are pic's of my Project
Yeah it has a very small curve to it
drewmitch44
I dont think that it is supposed to "curve". I think it should be strait on that boat. You can certanly put it in strait if it is slightly curved from rotted wood. The new ply will be straight.
Cast-A-Way
When I look at the cap of the hull it has a small bow in it and there is a 3x3 flat side where the mounts are
i386
if it is curved, it may be easier and stronger, to pop the cap and use seafoam.
Ok, I know we like our seafoam here at iBoats but this is taking it too far IMO!:D:D:D
(I knew what you meant TD:))
Cast-A-Way
I assume seafoam should be sea cast ?
If so how thick should I make the transom ?
Asides from the 3x3 mounting square that is 2 inches thick the rest seems to be about 1/2 inch
Oh by the way you guy's are great on this forum
Always helpful
This is my first project and I tell ya with the info here it has given me alot of courage !!
Thank you
TriadSteeler
Doing transom work with the cap on is difficult at best. I resisted taking the cap off and spent a week drilling, digging, & chipping while trying to contort myself under the splashwell. That was a week wasted for something I could have accomplished in a few hours. And I didn't even get all of it out.
I then gave in and removed the cap. Still kicking myself in the rear for not doing it sooner. Removing the cap, seems insurmountable at first. In reality it is a pretty simple process and refitting isn't much more difficult. In your case, with a boat your size, the only way I would consider not remove the cap is if you are going the seacast route.
If you are going to install a traditional wood/glass transom, you will want to remove the cap for the following reasons.
1. Simpler removal of the old transom.
2. Access from the top to completely grind the inner side of the outer skin.
3. You have to clamp the new transom to the outer skin (whether you glue it or glass it, to get a proper bond and prevent future water intrusion. Unless you want to drill a bunch of holes and install thru bolts in your new transom, clamping it with the cap on would be impossible. Think of a new transom as a Fiberglass-Wood-FiberGlass-Wood-Fiberglass sandwich that needs to be squeezed together as tight as possible. Air pockets in any layer of the sandwich are targets for moisture intrusion.
4. Installation of the inner skin. It is tough to get the top of your new transom encapsulated correctly if you can't see it.
When it comes down to it, it is easier to remove the cap than it is to contort for the removal, make modifications to bond the transom to the outer skin, and have the proper access to seal the inside.
Cast-A-Way
I will go the cap off route
any good methods to clamp or just use existing holes ?
TriadSteeler
Both,
Here is what I did to clamp the two pieces of wood together (Note: There are also SS Screws holding it. I snapped the pic right before I put those in.)
Here is what I did to attach the New Transom to the outer skin. I knew I was going to install a splashwell drain, bilge drain and Stern Eyes. I drilled those out and put Bolts thru as well as the clamps. At the bottom, I used spreader clamps to push between the deck/stringers and the transom. FWIW, Harbor Freight has C-Clamps real cheap.
fuzzeywiggler
A good way to check if it is suppossed to be curved is to look at it from the bottom. Go to one edge and follow it allong the bottom of the hull on a straight transom it will be straight accross and on a curved transom it will be curved...
Fuzzey
Cast-A-Way
I got some pic's here that shows the transom a little bit more
What do you guy's think
Curved or straight ?
Also what is the white bondo looking stuff in the bilge area ?
Thank you
redfury
Okay, correct me if I'm wrong, but I think we have a bit of a misunderstanding as to what exactly the transom on this boat is. The transom is the area that the outdrive is attached to, not the part on the top that is sticking out. You can look at my project links and it'll probably be very similar to mine. The transom is going to be located beneath the rub rail ( silver strip that separates the top and bottom halves of the boat.
Cast-A-Way
Well after spending the weekend in the boat here is where I am at !
I think I am ready to do the transom can I use
1-PL Premium
2-Epoxy
3-Poly
If I do a mayonnaise how thick can I butter this to help even out voids or different thickness in the transom area ?
Thank you
Cast-A-Way
need help on transom "Epoxy or Poly resin "
1-PL Premium
2-Epoxy
3-Poly
Thank you
Sorry for the double post
redfury
Wow, you work fast! I think we need a sticky on some of these kinds of things.
Cast-A-Way
Let's just say I am very motivated !
