I have a 1985 Johnson 120hp V4 VRO outboard. I can not get the idle speed to come down from about 2000 rpm. When you put it in gear it drops to about 1000 rpm. I have cleaned and rebuilt the carbs with new gaskets, needles, and seats and have checked to make sure the throttle plates are completely closed. I have also sprayed carb cleaner around the crankcase for leaks with no luck. Any ideas?
