Re: hmmmm
impeller was replaced in august.
have a few reasons to believe water is in the system; had the manifold problem which lead to water in the oil, so water must have been in the system then. Plus, When the temp guage was reading hot and I realized I didn't have the stat, and then I put in the stat, it leveled out the temperature, thus making me think that the guage is working, reading off the water.
I didn't run on muffs w/o the plugs in because I had already put in the antifreeze. I'll probably just worry about it next year....well, maybe i'll drain the antifreeze back into the jugs as to not waste it....hmmm.
