Bifflefan
- Joined
- May 27, 2009
- 2,933
Re: holley 4150
I do stand corrected.
Now it beggs the question, Why would you want a Double pumper, mechanical secondary, manual choke carb on a boat?
especially the manual choke part!
Sorry - wrong. I only use 4150 Marine carbs, can't stand the 4160 single inlet/transfer tube. The 4150 has dual inlets. The 4160 has a higher likelyhood of leaking at the transfer tube, especially after being taken apart.
Marine carbs have 'J' overflow tubes, different seals/bushing in the baseplate to prevent leaks, and run a bit richer than auto carbs.
