Homelite or Fisher Pierce outboards.....
Fouled Plug
Ensign
Pinkmouse, are you still frequenting the boards? I'm looking for a Bearcat outboard. Drop me a line via e-mail or post here. Thanks!<br /><br />------------------<br />I'm going to invent a TCW3/citronella oil blend and make a fortune!
homelite
Re: Homelite or Fisher Pierce outboards.....
click here for Homelite-Bearcats<br /><br />web page
59thunderhawk
i have a few of these 55 hp motors they all run great and parts are available.
cougar1985
theres one around my neck of the woods that id like to get, to play with.
59thunderhawk
Bill Boberts in Washington handles THE PARTS FOR THESES MOTORS 1360 914
O256
CATransplant
Uh, you folks are responding to a thread from 2001. The original poster is long gone.
geol
time to rejuvenate the discussion. My 55 needs work. It seems to run OK but has no compression on #4. And needs new motor mounts as the rubber has died. Also needs to have valve shims adjusted. they are mostly out of tolerance.
You have in your area as previously mentioned, Bill Roberts with a vast amount of knowledge and a large parts inventory for these engines. Check his website at Bearcat55.com. You also have NW Classic Boat Club based in your area, some of those members run these engines, check their forum for discussions about these engines. I have two I run frequently, a third I have just changed out the cracked block on, soon to be up and running. Went through the valve shim process myself on that last engine. Do you have any idea why you have no compression in #4? I have another engine (#4)here with no compression in #3. I was able to get one of the small LED lights in the plug hole to see chip in the exhaust valve, I'll be going into that one soon to replace the valve.
geol
Thanks for the Reply. I have talked to Roberts in the past. But the last time I emailed him I got no reply. I have also purchased parts from the 4cycle marine in California.
#4 is a mystery to me as the engine runs fine. no back fire or obvious popping from the exhaust. The ex valve clearance is only .004 which of course needs to be adjusted. The top of the stem seems higher than the others, so it may have been replaced and not seated properly. The valves are said to be Stellite. Which seems confusing to me. I know it is common to use stellite seats in HI temp applications. So is it the valve faces or the seats that are stellite? any way stellite should last forever. but the mating face would wear. The last time I ran it, The cooling water stopped circulating so either the impeller died or the engine scale plugged up the exhaust outlet. Because of the backpressure I suspect the later. I flushed it with pressure water and got some flow, but I haven't proceeded from that point.
I was given a Mariner 48 and have put it on the boat and rigged up controls and steering and done some minor repairs including a new impeller. The control cables were trip. Merc on the control box end and Yamaha on the engine end. So for now I am concentrating on getting MY 1961? Chetek lapsrake runabout in operation. [ 18'?]
So where are you?
George@awarenessworkshop.org
