maxum247
Thread starter- Joined
- Sep 18, 2007
- 1,363
Re: Homemade outboard
Any idea's for countering the problem of kick back when pull starting the engine as the blade is no longer there to act as a flywheel to balance things out, say a cast iron flywheel wasn't available for the engine being used?
Or will the driveshaft in the lower unit usually be enough to offset the difference of the blade not being there and act as a flywheel allowing the use of a regular light weight flywheel that comes on alot of the newer push mower engines?
max!
The blade acts as a flywheel there and adds some mass and momentum to the light engine in those cases.
max!
