Honda 4 stroke 15 hp
aardvark
only have had experience with inboards.....engine runs fine but doesn't seem to have a fast steady stream of water coming out.......as my neighbours say it should. Do I have an impeller problem??
Navigator
Re: Honda 4 stroke 15 hp
aardvark,<br />That would be the first place I'd look. Also,dont run the engine until you get cooling water through it. If you run it dry, you'll destroy the water pump, if its not dead already, and you could risk overheating the pistons,warping the heads, and scoring the cylinder walls.<br /><br />Take the lower unit off and check your waterpump impellor. Also look for debree caught in the lines. Thats probably all it <br />is.<br /><br />Nav
aardvark
Hi Navigator<br />Thanks for the info.........Did everything required.......guess what??? It was a deaad bug caught in the pisser !!!!!!!!! Who would haved guessed ? But I learnd alot on the way............THANX A WHOLE BUNCH !!!!!!!!!<br />Aardvaak
ahsah
Makes sense - if you had a . . . <br /><br />"a deaad bug caught in the pisser !!!!!!!!!"<br /><br />you wouldn't <br /><br />"have a fast steady stream cpming out"<br /><br />Either
<br /><br />Sorry I couldn't help myself<br /><br />capt'n steve<br /><br />I took the Searay jet boat out for her last run before we trade it in . . . sure going to miss 'er.
gss036
Re: Hookah
Re: Hookah
Do you realize this is a 10 YEAR old thread?? Maybe time to start a new thread.
